paint question.
Howdy folks! I was wondering if anyone has tried to shoot those acrylic craft paints thru an airbrush. Im talkin about delta creamcoat ect. If so; what do you thin it with.
Thanx,
Acrylics can be thinned with water, although I’ve had better results with Poly S Acryllic thinner. You should be able to find the thinner from any store that sells Poly S paints.
I use these type acrylic paints regularly through my single action external mix A/B. Works very well, but needs a good seal coat after painting, like Future. This type acrylic is very soft, but a heck of a lot less expensive than Polly S!
Brian [:D]
OPPS! Forgot to say, I use regular tap water to thin, about 3:1 paint to water.
[banghead]
thanx fellas!
Happy Mottling!
