Paint cross reference
Was wondering if there is a list out there for paint number cross referenceing
Manufacturer to manufacturer…ie testors/tamiya/gunze etc
Hi,
Maybe, not that clear, but you may try some FSM issues where the USAF, RAF and RLM colors are crossreferenced with manufacturers numbers and FS numbers. I had found those charts really useful.
Greetings.
Try http://www.hotel.wineasy.se/ipms/stuff_eng_colorcharts.htm for the cross-referance.
Thanks guys
most helpful
go to www.mundohobby.com
select links/clubs
then IPMS and IPMS Stockholm.
All you need is there
I found the IPMS Stockholm list more of a starting point than an end. At least with the Tamiya colors they recommend the closest color, which is not necessarily a match. For instance, for Sea Grey RAF, they recommend either Tamiya XF-53 or XF-54. 53 is a little dark, and has no blue in it, whereas 54 is close to US Neutral Gray, with no blue, and is quite dark. The Polly Scale line and the Acryl line are not listed in this guide, which I am sure is being updated.
