I have a Paasche VL double action airbrush, as you may have concluded from the subject of this post. Anyway, I noticed today, that when I’m trying to spray lighter amounts of paint, with the trigger about half way back, the paint will spray for a second, and then stop for a second and does it repeatedly and regularly. It’s not a sputtering, but it’s as if the air flow is stopping every other second. When it sprays sprays, it sprays fine. Also, it will spray fine if I am spraying with the trigger all the way back for larger coverage.
I thought at first it would just be some paint buildup somewhere along the way, but I cleaned it as well as I could and it still does it.
The medium I’m spraying doesn’t matter either, as it does it with water too.
What kind of air source are you using? Diaphragm compressors can pulse and I’ve found they seem to pulse more when the AB is running wide “open”. A pressure regulator can help. So can using a tank to settle out the air flow before the AB.
I’m using a compressor. It’s an older one and I have no clue the make or model, but I do have a regulator and moisture trap on it. Also, it doesn’t pulse when I am spraying larger amounts of paint, even with full airflow.
I’ve had the same problem with my Paasche VL. I’ve tried thinning, changing air pressures- lots of stuff. Same results- pulsing, and it’s not timed with the compressor pulses.
I don’t know what the problem is, but my Aztek doesn’t have the problem. Wonder what it is…
Badger 100 series can pulse if the head washer gets squished or damaged, but I don’t think the VL has an equivilent, at least I don’t see one while looking at the Parts List (courtesy of Dixie Art). Perhaps it’s a case of a improperly cleaned or damaged tip (cone) where it sits in the main body?
I actually replaced both the needle and the tip and had the same problem. Now- the VL I have is fairly worn, so there may be some sealing issues, but nothing that is appearent as far as parts that you can replace.
Darndest thing, thing though. It sprays very nice when it’s working right. The trigger control is better than the Aztek.
Usually when you have a interruption or a sputter in the paint flow from an airbursh there is an air leak at the tip or the needle bearing. On a VL use the wrench to tighten the tip a little more, if the problem continues you might have to replace the needle bearing.
I used to use a VL. I had the problem with mine long ago and have also experianced with my Iwata. In both cases I was using very low pressure, very close, with thinned media (enamels). I found that thinning the paints further was the fix. I never had any spatter or anything, just like you guys. It would just stop flowing. Not even higher pressure fixed it. A few more drops of thinner always works for me.
I tightened up the tip, and thinned the paint more than I usually do. That seemed to do the trick, it doesn’t pulse anymore, and I can control the paint flow without it spattering.
The only thing I have left to do, is find out how little I can thin the paint before it causes a problem. Right now, the mixture I’ve been using is a little too thin, and I can’t get the coverage I want. I should be able to figure out a good formula when I get some time to play with it.
