P-47 help
Given the amount of Jug lovers on here, i am sure i will get some help with this. I have just bought a set of 72nd decals which include markings for a P-47C. But the only kits i can find are 47D Razorbacks. Is there any major difefrence between the two. Its a toss up between the Academy and the Tamiya kits. I already have a couple of the academy kits which look nice and are a lot cheaper. But if the tamiya kit is more sutable i would go for that one.
So, any advice.
From what I have read, the C model was 6 or 8 inches shorter than the D model. The added length on the D was between the cowl and the cockpit.
Thanks. I conervted that to metric and at that scale its about 2.7mm. I think i can get away with that. I take it that means theres an internal change to the engine which increases the length.
Here is an example of a conversion to a C model. It is of a 1/48 kit but the conversion work would be the same.
hsfeatures.com/p47csb_1.htm
[:D[ Perfect, thanks.
My references do not support this. Most differences were internal. There main visual differences were the addition of lower cowl flaps on the D to assist in engine cooling. The length increase difference was betwee the B and the C.
P-47C
and P-47D
Stik, thanks for those pics. They help explain the build that borg posted a link to. That looks an easy enough job.
You’re very welcome Bish. In 1/72 it should be a piece of cake. Fill a couple lines and your set. Jus take note that some P-47s later had notched lower cowl flaps so you may have to do a tad more than just filling some lines depending upon your kit.
Thnaks stilk, i will make a note of that for when the time comes. I have saved the link borg gave me.The aircraft i have markings for is a war weary 47 used as a lead ship by one of the bomb groups. So i should be able to find some photos of the aircraft so i can check there. I think i am going to go with the Academy kit, its a good kit and seems silly to pay nearly 3 time more for the Tamiya.
Bish, Stikpusher is right about the demensions on the Thunderbolt. That is what I get for trying to remember instead looking it up. As soon as I read about the cowl flaps I knew that I had given you wrong info. Hopefully I did not screw up your kit.
Nope, not at all. I don’t even have a kit yet, just the decals. It will be a very long time before i build it. Even if the length was different by that amount, i would not have changed it as it is so minor in this scale it would be unnoticeable.
