I have an Academy P-38J and have been pondering building it. While looking it over I noticed that the kit has two different nose cones in it. Why is this? What is the difference? If it helps the kit is the one with decals for the “Putt Putt Maru” natural metal aircraft.
I have the same kit in my stash.After looking they appear to be the same part, they have the same gun and cannon ports as well as the same panel lines.The instructions call for part#C-2 although you could use either one.As to why there are two, maybe somebody else has the answer.[2c]
TOM
For that kit they use the same tree for both P-38E, P-38J, P-38L Droop Snoop, P-38M, F-5 kits and most parts are the same but the different gun nose is for the early “E” model as with the control yoke it too is on the same tree
