I started building a Hasegawa 1/72 Kfir C-2 and was planing on puting a Hasegawa pilot in it. So I was testing fiting the pilot in the cockpit and found that the pilot is really out of scale since he sits real high and his arms almost come out of the plane, or that the Kfir is. Can any one help me out on what is worng the pilot or the plane. Thanks
I wouldn’t neccesarily condemn your pilot figure as being “out of scale”. He may just be in a pose that is wrong to fit into the tight cockpit of your jet. You may want to modify the figure by removing and reattaching the offending parts in a more favorable pose, or simply try another figure that may fit. In the future, if you are planning to include a pilot, always test fit the figure before closing the fuselage, this will help you avoid the issue that you are currently experiencing.
Remember, patience, planning,patience,planning…= a succesful project.
Regards,
Steve
Thanks, I will try to fix it tomorrow I put in back in its box for the night for some cool down time so I will not get mad at it.
