OTS 2015 (One True Scale or 1/72)
2015 One True Scale
  1. any subject is welcome.
  2. please post WIP pics. Also please post WIP in the appropriate forum so more people can admire your build.and learn from it.
  3. this will run from 06JUL15 thru 31DEC15 ,
  4. crossovers are fine
  5. if you are starting a new kit, post or PM me a picture of the box art i will post it on the roster page along with finished builds.
ROSTER
68GT - ESCI A-7E
Aussie747 - Hasagawa NP-3D
B-One Fixer - Heller AWACS, ESCI KC-135A to R
CallSignOWL - Airfix A6M2b Zero
Checkmateking02 - Airfix Hurricane MK1
DukeMaddog - ModelCollect T-90
Lewbud - Hasagawa F-14
ModelCrazy - Revell SDKFZ-7/1 -7/1, Kubelwagen
Rob S - A-26
Simpilot34 - Italeri F-15E Strike Eagle
Taxtp - Airfix Chipmunk, Airfix Hawker Hunters F.Mk.6; FGA-9/Mk.58
Theuns - Academy T-6G, Airfix DH Tiger Moth, another T-6
Waynec - Aoshima JGSDF Aviation Bowser,Toxso SCUD-B
i do a lot of warwheels and \trucks in 1/35. this is my first truck in OTS. i got it to practice on Aoshima before getting others which, of course, did not work out as planned as i stare at my Aoshima OTS stash which includes a PATRIOT, TANK TRANSPORTER, 2 TYPE 74s, and the 8x8 AFV. OTOH i could build an OTS JASDF aeroplane to park next to my tanker. Plus an annual local is coming up and i have done quite well in this scale.
plastic one piece wheels which are hollow on the inside as are the bottoms of vehicle cargo boxes. wouldn’t be seen on a base but i will fill them in. shouldn’t be all that bad. it isn’t camouflaged so that’s good. i have Tamiya JSGSDF OD but will look for an MMA or Vallejo match so i can brush touch up easier.
Great sign me up solong for an Amodel TU 128 . will be out the box in alclad.
I got some new reading glases today as my arms seem to be a tad short these days for the small stuff LOL.
Theuns
Holy cow this Amodel 128 is a bad kit :frowning: The fit is bad and the parts are full of flash. It will not be the shake and bake kit I was hoping for…will take allot of work to get right.
I might have to substitute it for a fast easy build to get some build mojo back.
Theuns
here is the basic wing and cockpit asssemblies.
The cockpit will be very bare but that is OK< not much to be seen through the small canopies anyway.
Wayne please also putme down for this 1/72 Academy 1/72 T-6. It will also be a fast no frills build most likely in South African AF scheme.
Thanx
Theuns
Shake and bake, three words that until now, have never been uttered in the same sentence as Amodel. I’ll be down for something, just don’t what.
Having neve built an Amodel I now know what they take to build…
Theuns
Wane,
Put me down for the 1/72 Italeri/Tamiya F-14A Tomcat I’m going to build for Stick’s Gulf War GB. I won’t get to it for a little while though.
Steve
If you like Amodel, you’ll love Mach 2. Unfortunately, like Amodel, the kits they produce are usually the only game in town. Wayne, put me down for an ancient (raised panel lines) Hasegawa F-14A. Now to find me some Jolly Roger decals to go with the Zero I’m building for the Pearl Harbor build.
pics don’t show it but everything is now primed and ready to paint. chassis is black, exhaust is metallic gray or aluminum, upper body is JGSDF OD at least the Vallejo AV equivalent, and cab top is canvas so a slightly lighter OD for contrast. wheel hubs should be black but will be OD for wash effects. this won’t be dirtied up much.
Not a huge amount to report on with this build,the cockpit is just dressed up with tamiya tape belts.
Theuns
painting looks better. ready to start putting the big parts together. started with mounting the tires, applied too much pressure and snapped a differential in half. that created a 15 min fun fix and now the right front tire is just a bit too high. not going to try to fix it but it looks like this will be parked on dirt instead of concrete. looking for a 1/72 JASDF helo now. there are some CH-47s but all seem to be back ordered.
I have to wait for my AM decals for aleast 6 weeks , so my T-6 will be a slow build.
Theuns
monitoring :slight_smile:
painted. upper is Vallejo olive gray which ls close to Tamiya JGSDF od. chassis is black. canvas top is a Vallejo german green which also looks close to Tamiya JGSDF green. mirrors wont be on until after decals and most of the weathering because i know i will knock them off. learned a lot for the next OTS builds
[/URL]
[URL=http://s172.photobucket.com/user/waynec_kits/media/0-2015%20OTS/JGSDF%20FUEL%20TRUCK/FUEL%20PAINTED%204_zpsotblxpoq.jpg.html]
one thing i will do in the future is paint the edge of the windows black so the thickness is hidden a bit.
decals were amusing maybe because i don’t like doing them and get impatient. one slipped on me and i damaged it moving it back. not too badly as it’s a Japanese character at 1/72 so there is more forgiveness with broken “text”. also some silvering again my fault. first time i airbrushed a flat coat and, like Vallejo paint, it looks much better after it dries. now for the fun part, washes and weathering. i think one front tire sits .5mm off the ground after fixing the differential i broke so a base is due. if i can find one of the JASDF or JGSDF CH-47s i will use that and dust up the truck from rotor wash.
Wayne, that is a cool idea with the window’s edges.
Here is the T-6 sofar. The kit has one mistake though, the arrow shows the starbord elevator to have the tab actoator on the top. This should be on the bottom.
The t-6 has only one elevator that gets swapped arround.
Theuns
Looking good guys!!! :slight_smile:
Hey Wayne! I now have a model (or three) to add to this that I got at the Nationals. First is a Modelcollect T-90 with welded turret; then I have a tractor and trailer for my V-2 rocket. Gonna see how many I’ll be able to finish.
Hey Duke
good to have you. i started on the Toxso OTS SCUD. haven’t posted here yet but have a thread in armor and in gulf war 1 GB
