OT-76
Hello again:
This is the model actually on my workbench, a OT-76 from Dragon with some extra stuff from Mig Productions, Tiger Models, Friul …
The assembled kit:
Base color with some highlights
Washes and some chipping
Thanks for looking
heh Jose!
Looking good so far!
A regional style is evident in your models. A artistic touch to mono tone finishes which adds interest & depth to a otherwise drab finish. Details and surfaces standout, drawing the viewer in for a closer look.
Tanks for posting!
[t$t]
Great texture & rusting/weathering. You really know how to present a single-colour tank & make it all stand out!
Looking good so far Jose Luis, always a pleasure to see what you’re going to be working on next! [B]
!http://th38.photobucket.com/albums/e105/CommentCrazyGirl/Smileys%20Action/Hobbies%20Games/th_20070813-090332-57.gif
Great work and just with acrylics. I can’t get it that nice with oils…LOL. It’s all about technique and yours looks impeccable.
Great build.
It’s really worth it to use those aftermarket parts, they really make a difference.
Hello again my friends
I particulary love one color vehicles, as there´re plenty of color posibilities to make an atractive final look. It´s my first 4OB vehicle and I must say that I love this color, it´s very easy to bend and for weathering
The dust was made using Tamiya enamel paints (general dust), oils (to add constrast to the dust) and acrylic paints (for vertical striking).
And the finished kit
Thanks for looking!
Regards
Stunning work as always Jose! You should really consider doing a lengthy, step-by-step article on your processes. If youve got the time that is!
Clapping HandsOutstanding good work Jose.
That headlight’s a killer and the base color unique and convincing.
Very good job all around.
!http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
Supurb!!! I try to attain that look, and fail every time!! [Y][:D]
Very fine work Jose…[:)]
Very nice. I love your work.[t$t]
I agree with Beltfed. Could you do a tutorial on how you do it?
nice job on the build enjoyed seeing the pics.
Ron
Many thanks for your opinion!
I´ll be glad to make a little resume:
1.- Preshadow. Over the primed tank.
Belive me, this step is very important. This helps to get a more atractive base color with natural shadows in the lower part of the hull
2.- Base color
For this step I used a mix of XF-73 and XF-74, with some XF-60 for the highlights. No need to make shadows, already present in the base color (preshadow). Use VERY THINED paint to paint the base. I like to use 80% thinner, 20% paint. To paint completely the base coat, I use to employ 3-4 coats. ALSO important. Paint the base color in thin coats like transparencies. Not try to paint a solid base color. Make it little by little, in a no homogeneous way. This REALLY HELPS to have a more rich base color. Why spend trying to change the base color with filters when you can make directly a nice base using your airbrush? Filters can help, but they´re not the best weapon at your disposal. Base color is the clue here.
3.- Tutti-Frutti
Yes, I know, a strange name. Using your acrylic paints (I used russian green, from Andrea, NAC-06), I painted some details as rivets, handles… this helps to highlight the most atractive parts of the vehicle.
In the above picture, no filters, no oils, just modulated base color!
4.- Washes
Using oils, make a traditional wash to enhance the details. I love natural umber and black, also a dark green.
The next weathering steps are the typical you can find on articles and magazines, pigments and oil paints. But the clue, my friends, is an interesting base color. Many modeller got nervous because they see the plates and surfaces so uniform and boring that they start applying filters and oil colors desesperately to achieve an atractive base color. So, spend you time in an atractive base color and the rest will be much easier.
Hope this helps
Very nice work as usual Jose-Luis and done quickly as well. [Y] [Y]
Very nice. I like this way of painting a base coat. and not messing around with filters later.
Fantastic! I love the mini-tutorial you provide and excellent pictures! Interesting is your unique technique, getting away from filters and such.
I tried something similar and ended up with it all being wasted because my cover color was sprayed too thick. If you pre-shadow you must NOT spray your regular color on too thick and not try to get in every nook and cranny, that’s what the pre-shading is for…a huge DUH on my part.
I have a heavy hand and I think for people like me it’s best to do the shading afterward. You cannot argue with your results they are great. It just didn’t work for me, maybe when my technique improves if ever it will work, I never give up and will try it again, there is merit to that technique no doubt.
I am very happy so far with just laying down a nice coat of primer and then the color I want then shadowing. BUT the trick I found was to use a lighter version of the color you want. All the added shadowing will darken the overall color especially with oils. Oils seem to get darker with time as they found with the Sistine Chapel…[:)]…ha ha. But it kind of surprised me how much as I am new to oils.
I think from what I have found it 3 basic layers, your shadows, the color of the model and the highlights. it really doesn’t matter how it’s done or what type of paint as long as it looks good. Although I have found that the Polly scale acrylics look more natural then the Tamiya, smoother finish and a warmer more natural color. The Humbrol enamels look really good for anything that needs some natural depth like tarps and canvas or jeep seat covers, things like that. It seems like each type of paint has it uses and each manufacturer also can be used for certain things better then others.
I’m finding out which is best for what. The amazing thing is the difference in color from one company to the next. One company’s Khaki is another company’s green…LOL…that made me just scratch my head.
But the model did come out amazing and very realistic looking which to me is the end game. I know what armor looks like, even Russian stuff as I was around a bit of that too during training.
When I really examine the photos in my opinion the recesses look more realistic then doing it after the model is sprayed. I will have to try this technique again, it’s logical and looks really good. Maybe with some models this works better then others. I’m sure I am at the same point as many other model builders and have not achieved my goals in terms of getting the look I want. I’m getting there though, I am really working hard on getting the figures painted, the eye’s are so important.
Great job!!![Y]
Very interesting post! Let´s talk about paint and materials!
Obviously, it´s not mandatory to make a pre-shadow before the base coat. In fact, most of the TOP modelers in the world, do not make it. But whatever technique or material we use, we must have a complete control and knowledge of the materials and techniques we use and the results they offer. We must know which material is suited for a concrete task and the results we´ll achieve using it. It´s crucial to know how the diferent products works.
I am very happy so far with just laying down a nice coat of primer and then the color I want then shadowing. BUT the trick I found was to use a lighter version of the color you want. All the added shadowing will darken the overall color especially with oils. Oils seem to get darker with time as they found with the Sistine Chapel…ha ha. But it kind of surprised me how much as I am new to oils.
Actually, most of the modelers do the same as you and it really works. An airbrushed solid base color and, once dry, they start highligthing the base color to achive a more atractive looking and then, a general shadow to highlight volumes. But always try to paint the base coat in several very thinned coats. Maybe you will spend more time painting the base color (2-3 sessions), but that base will be smoother, cleaner and flawless.
And Yesssssss, oils obscure the colors, so, what you said is a BIG TRUE. Base color must be always lighter than the final color we´re looking for. But not only the oils darken the base color and the general appearance, also the washes, a general airbrushed varnish coat, pigments, filters… Depending of the desired levelof weathering, your base coat must be lighter or hipersupermegalighther! :slight_smile:
I particulary love oils. Why? They have a slow process of drying (you can make corrections, impossible with acrilyc paints) and they allow to make smooth color transitions and transparencias. The catalog of colors is almost endless at your favourite art shop! And oils match perfectly with pigments.
And for some specific weathering, you can use only oils to finish a tank. This Tiger was weathered just with oils over the base color. No filters, no base color highlighting … just base color and oil.
It really doesn’t matter how it’s done or what type of paint as long as it looks good. Although I have found that the Polly scale acrylics look more natural then the Tamiya, smoother finish and a warmer more natural color. The Humbrol enamels look really good for anything that needs some natural depth like tarps and canvas or jeep seat covers, things like that. It seems like each type of paint has it uses and each manufacturer also can be used for certain things better then others.
I always use Tamiya or Gunze Sangyo for airbrushing. Why? Are they better? Are they color catalog perfect and realistic? Not neccesary, but I perfectly know their results on a kit. I know how they´ll reack with oils, thinner … Maybe I´m not using the best suited colors, but I really control this paints. So, first task is to work always with the materials you´re more confortable with. I always paint with this paints thinned with 60-80% of thinner. Less is more.
And there´re sooooo many products, Vallejo Aircolor, Life Color, Humbrol … no time to know how to use all of them properly! :slight_smile: I prefer to squeeze the properties of these paints altough they´re not the best.
It´s no neccesary to have all the products available, just the materials you´re confortable with and you know how they work.
And the best reward is to feel proud of your work, no matter what your wife said about "those little tank toys over the kitchen table!
As more kits you make, as more fun you´ll get and more your results will improve
Regards
Correct! But you can also add some filters to enhance the base color constrast or to soften any sharp incorret transition.
