Ordered Iwata Revolution SAR need additional advice
So just getting back into the hobby I have decided to buy 2 airbrushes. 1 for basic priming and coverage and the other for finer detail work. The detail brush will be an Iwata HP CS. Coming back to airbrushing after so many years I have forgotten quite a few things… Please help me make the best decisions possible. I plan on buying an Iwata Smart Jet Pro. Using 2 airbrushes I would like to use the quick disconnect connectors. Just not sure which connectors I actually need. Male and female? Hose type? Are braided hoses better? I thought I read that coiled minimize moisture… Thanks all for the help! Cant wait to get started!
I have an Iwata HP-CS, an HP-B Plus and a SAR powered by a Smart Jet.
You need this → www.chicagoairbrushsupply.com/quco1set.html
You also need an AD9 male connector for your 2nd AB. You can get both at Chicagoairbrush or Amazon.
The quick connector works flawlessly. I use my SAR 80-90% of time. It’s an excellent AB for spraying base coats and not-so-complex camo patterns. I hardly use a paint jar with it, though. Badger or Paasche paint cups are compatible with the SAR and it’s so easy to use and clean the SAR when you use a paint cup.
In addition to what Chrisk-k advised, personally, I don’t think the make-up of the hose will make much difference for you - the Smart Jet has a moisture trap attached. I believe the SmartJet Pro comes with a nice Iwata braided hose so no worries.
