This has probably been discussed here before but do you think I can find it? Not a chance! I’ve got 5 hours left on Mad Komet Day and today is the day my AB decided it only wants to spray paint intermittently. Even when I rock the lever all the way back I don’t get a steady flow. Thinner flows freely through it, though. I’ve coaxed it enough to do the general pattern but now I’m trying to do the mottle.
Now, I pulled the nozzle apart to see if by chance the air passages are a little blocked but they’re open. I pulled the needle out as well and it was fine. The only thing I haven’t done is take the spray tip off to see if there is any bit of dried paint in there because I don’t actually know how. It seems to be on quite solidly and I’m not sure if it’s press fit or threaded. And yes, I always back flush the AB after use.
I did notice some thinner spitting out between the nozzle head, the body and the O-ring which suggests a blockage somewhere. I tightened it up. Any help would be greatly appreciated!
