Old School zimmerit...the Verlinden way...Tiger II Tamiya
So, for you younger wippersnappers who don’t remember he days when there was NO AM zimm to be found, and certainly none molded in the kits, a pretty solid technique using a 15W soldering iron, a pencil and a ruler…pioneered by Francois Verlinden and, albeit poorly employed by me on the Tamiya kit:
First, draw out the pattern in pencil:
Then, heat up the ol’ iron and start melting styrene:
Assemble, paint, decal and weather …badaboom badabing…:
If you’re scared to try it, believe me it’s easy…just get an iron and practice on scrap…it goes quick, looks pretty good and is fun to do.
Your a brave man, but nice finish. I prefer to use Miliput myself, but nice to see things still being done the old way’s.
I haven’t seen this method used in a very long time, but dang if you didn’t do it a whole ton of justice! Splendid work, indeed!
Love that KT! It looks the business. :slight_smile:
Yep, nice work. My first attempt at it was also before AM parts were available. I used Tamiya putty spread on the surface with an artist’s putty knife and pressed into it with a narrow flat-blade screw driver. That was also very accurate-looking.
I never attempted that technique with a soldring iron, though. Scary! =8-0
Gene Beaird,
Pearland, Texas
Yeah, crockett, that was poorly employed! Not! That looks fantastic! I may get brave and try this sometime, and thank you for sharing! I have never seen this technique.
Very cool! I always used the putty and razor saw technique but it’s great to see the other ‘old school’ way here. Nice kitties!
Old Shcool techniques “Still a valid option”[Y]
Taking thiings a step further, as on this SS Wiking Panther, you can also simulate “chipped” zimm and alternative pattern(s) found on some vehicles:
Wow! Yeah, I’m impressed. Looks like you’ve been using this technique for a while. You make it look easy.
Steve, you are very inspiring. I wish I had the courage to attempt your zimmerit.
Very nice work,but I need to stick with molded in zimm
First rate!! Looks very real, more so that some of the “pre-made” stuff. I salute your bravery!!..now where did I hide that old tiger kit…
(Francois)Coiske from Lier/Belgium, always inspired the whole world with his hobby… Love the nice clean Camo colours on your Tiger II.
First time i made a zimmerit with Milliput suferfine of Tamiya(It was a hell) On the next project i use the tube putty with a tool (zimmerit coating roller) from trumpeter.
Wow that looks good, I have a old Tamiya kit in the stash going to give this a try.
I think Verlinden used a soldering iron to also make penetrating hits
