So, I’m going to try an oil wash onh my phantom, and it’s my first time. so any instructions would be helpful. also what color oil wash would i use to accent panel lines on an SEA scheme? Thanks, Tank
Lots of ways to do a wash, but here’s mine. I thin the oil down so it’s about like strong Coffee in color & consistency. I only apply an oil wash over a gloss acrylic top coat. Future is my favorite. Use a small brush, 3/0 or so, with a good point. load the brush with some paint & touch it to the recessed panel lines. The paint will flow for a short distance due to capillary action. Keep moving down the line till it’s done & move on to the next. When done, carefully wipe off the excess paint on the model. I use a Q-tip moistened, not wet, with mineral spirits. If you remove paint from the panel line, just repeat the process till it stays. It’s slow & laborious, but gives good results. Some like a sludge wash, but my experience with that technique has been mixed, so I’ll let someone else describe it.
For an SEA camo, I’d use Burnt Umber for most of the wash, with Paynes Grey to accent control surface separations.
Regards, Rick
ok thanks a lot
i’m having a problem with my oil wash. sometimes the wash is really nice and dark and flows along the panel lines wonderfully. other times it just balss up in one spot and doesn’t flow at all, and other times it is extremely light in shade? what is the problem?
I recently had the same problem with one of my oil washes. Unfortunately, I’m not sure what caused it, but I’m also interested in hearing from others what might have gone wrong. I’m rather perplexed, since I have been building three planes simultaneously (all P-40s), and on two of the three the oil wash worked fine. The only thing I can think of is that I either didn’t apply enough Future on the third, or actually applied too much so that the recessed lines were filled in spots [%-)].
Hope someone can steer us straight.
Mark
