Well, here’s what I got so far (I didn’t start early. I swear) It is kind of creeping me out. the M-35, dispite the fact that it’s an older kit, is almost literaly putting itself together. I got a feeling something’s going to happen, soon…
Here are the photos (sorry about the poor quality. I only have a Kodak E-Z share C-430.It’s not the best, but it’s the only one I can afford to have)
[View:/themes/fsm/utility/
:550:0]
This should be an overview of all the sub-assemblies in their current stages. (I perfer to work on multiple assemblies at one time, so I don’t have a lot of down-time. Mabe that’s why it already looks too good…)
[P.S., ignore that red/yellow caboose in the background. It’s a kitbashing project that has stalled for now.]
:550:0]
Here’s the chassis and drive-system for the truck, after I super-glued the brake lines to the brake system areas on the wheel hubs (It turned out better than I thought)
:550:0]
Here’s the finnished product for the brake lines. The super glue was an older tube, and didn’t cure fast, but it sure did come out fast[:S] I hope the brake lines are still visible after paint…
For the brake lines, it’s nothing special. It’s just strands of copper filiment taken from an old lamp-cord. I cut it longer than I thought I would need, and then I drilled a fairly deep hole into the mounting area behind the round disc on the axel (the brake hub?) After that, I just super-glue it into the hole, and then I thred it along the chassis, applying a drop of glue at turns and in the mid-point of long strait runs.
(Note, I didn’t have refrences when running the lines, so accuracy is not garunteed. I just did it as I thought the lines were done on the real M-35s. I’ll just claim artistic lisence, if it turns out to be wrong)
:550:0]
Here’s the last photo for this update: the cab. I did some scratchbuilding to place some details that (I think) were fairly common in the M-35s. I shaved off the molded gas/brake/clutch pedals, and made new ones with styrene I got from a $0.98 for sale sign from the hardware store. (Admittedly, I think it was a bad call. the new pedals look bigger than the original)
The channel-like thing next to the driver’s seat is a scratchbuilt rifle rack (more or less accurate) that sort of follows a photo of a rack that Hans von hammer showed me, back in the Real or Model. Episode 2 thred. He said it was used vertically in the M-35 behind the driver’s left shoulder, which was what I tried to replicate.
I don’t have any spare wepons laying around (other than a WWII German K-98) so I’ll have to leave it empty for now. If I get a modern U.S. infantry kit set one day, I’ll salvage one of the M-16s for the rack. It’s not the best, but I have not scratch-built with styrene before. Man I have a lot to learn with that.
The thumb-print on the floor of the cab was sort of a mess-up on my part. When I went to glue the side of the cab/hood into place, I didn’t realize that glue came up through the seam, and onto my thumb. I’ll need to buff that out before painting.
