nozzel help
Ok. I acidentally left the device that tightens/ loosens the nozzel of an airbrush out on the kitchen counter. When I realized it was missing I went there except that it was gone. I found out that my parent thought it was trash and threw it away. I just came inside from searching from the garbage cans. I found nothing but trash. Now I can’t use my airbrush because the nozzle needs cleaning and there is no way of doing it. Is there any way to replace this lost item?, or I’m I getting over worked?[BH]
This should be a piece of cake. All you’ll need is the make and model number of the AB and a good description of the part (in this case, nozzle wrench), though it would help if you had a part number as well. With this info you should be able to go the company website, or any AB supplier for that matter, and order it.
hey oddjob. If you can’t get it, then try the lacquer thinner that walmart sells for about five or four bucks.
that’ll clean it well!
