No Rich Formatting using IE11 on my windows 8.1 machine!!
When I go to reply to someone on any finescale forum using IE the “Rich Formatting” window does not open. That is to say a window opens to type in text but the window with all the emoticons and formatting options does not appear. If I use Firefox it does. What gives? Mike
Under IE11, you need to use “compatibility view” otherwise you lose all formatting controls.
Click the gear wheel icon at the top right of the screen, select “Compatibility View Settings” and add finescale.com to the list.
Phil,
Thanks very much!! Problem solved.
Yea!! my problem is solved [Y] (just "returned to IE- may stay may not [co] )
Thanks for the solution.
