no idea how to use airbrush
I need help guys. So I bought my first airbrush but I have no freaking idea how to use it at all. I mean I know how to use it, but I have no idea how to change needles or tips or the proper way to do so. I dont even know what all the components are. The thing didnt even include instructions on how to change things or anything. Kind of discouraging for a newbie with no experience. So if anybody has links to posts with instructions or how to guides I would be greatly appreciative. I have the model master G222. I know I know its pretty crappy but hey like I said this is my first AB and I didnt want to spend a ton of money yet on an iwata till im confident in my skills. Please help!!!
Search online for instruction manual guide/booklet for your airbrush brand. Better yet, where did you purchase the airbrush from? Ask the vendor to send you an instruction manual.
@BlackSheepTwoOneFour I bought it from TCP Global. Thing about it is the “Instructions” that came with it are the ones TCP printed up for it. And they are not even instructions. Its just a view of the expanded airbrush and a parts list of the components in the airbrush. They dont have an actual usage set of instructions or how to change things or how to properly disassemble it for full cleaning. And I cant really find much online except for reviews…not really any how to guides.
Hello!
How about if you post the picture you mentioned (the expanded airbrush) and we will try to go from there?
Good luck and have a nice day
Paweł
Hi Reaper 420,
The Master G222 is likely a decent first AB. It’s similar to the older Iwata HP-C. It comes with three nozzles 0.2, 0.3, and 0.5 mm and with matching needles. I believe the 0.3 mm is in the brush when delivered. I’d start out just using that one (changing the tiny screw in nozzles might take some practice). To remove the needle, first unscrew and remove the handle from the AB, then loosen the little nut that surrounds the needle ( on the needle chuck) and slide the needle out from the rear. DON’T try to push it out through the front or you’ll damage the nozzle. Be careful with the point of the needle - it’s sharp and a critical part of the AB so don’t damage it.With paint (thinned) in the cup, push down on the lever to get air to flow and, simultaneously, pull back on the lever to get paint to flow - the further back you pull, the more paint comes out. A good place to start might be:
https://sites.google.com/site/donsairbrushtips/home
There, you can also see Don’s reveiw of the Master G22 (same AB but without extra nozzles/needles) and find lots of tips. YouTube has lots of instructional videos - just search Airbrush. HTH
Best advice I can give is to consider an airbrush a paint brush that lays down a layer of paint without brush marks. Do not consider it a spray gun. If you think of it as a spray gun you may try to paint too fast, from too far away. This leads to orange peel, and irregular paint density.
Also, when you start painting, practice on some scrap material. Do not start on a good kit. I know so many folks who have messed up a good kit doing it that way!
I’ve got my eye on a Sparmax dual action airbrush I saw at my Hobby Lobby a couple days ago. Looks like it’s gonna be on my Christmas wish list this year. LOL!
Thanks alot Bick and the rest of you as well. The information you provided is really helpful and I feel like I can start soon. As for airbrushes at hobby lobby, a new one just opened up here in Dublin CA right ariund the corner from my house. Couldnt be happier. They got some nice AB sets too, once I get good enough ima go and buy a new one from there, probably an Iwata, not the Neo though, but an actual Iwata.
