NO FUTURE HERE....
what other products can i use besides Future coz Im having a hard time finding it here in the Philippines.Can i use other Johnsons floorpolish products such as wipe n shine?What about using varnish for a finish?Hope for your immediate reply.Thanks guys.[:D]
jeng I wouldn’t use varnish on a model. I don’t think it would work that good and might not be compatible. I would try the Johnson wipe n shine but TEST it out on an old kit or just some scrap plastic. Paint the scrap first then try the wipe n shine once it dries to see how it works.
Eric
If you can get Johnson Products there … look for Johnson’s Klear, I hear it works pretty much the same as Future.
I have the same problem as jengjeng. I have never seen Future here in Japan!
I’ll look for Johnson’s Klear and see what I can come up with.
theres no johnsons klear here also so i decided to try the johnsons wipe and shine and so far the results have been a little shiny but quite satisfying enough.ive used it over a 1/144 academy p38 with an academy silver enamel painted coat.havent tested it on any of my tamiya enamel painted models.ill try on it next.thanks for the reply guys.
You just need to make sure to get an Acrylic floor wax (not actually a wax, but they are still usually called a wax).
The key is to find somebody cool enough to send you a bottle of future via USPS. It might cost you twenty bucks by the time you factor shipping ect but one bottle lasts FOREVER!!
I recently sent a bottle from the UK to a FSM forum member in Argentina. Indeed the cost of p&p was higher than the actual product, but it DOES last forever. At least, I know the bottle can cope with the transport!
Future is an acrylic floor finish for no wax and regular floors. Look for something else similar but be sure to test it first.
John
