Hi guys…normally an armour model maker but I NEEDED a small change…
Well as you can see some habits just do leave you.
Well here it is…Ural Front…AD2034 Modeled as a A KV-2034
Converted the following …
Changed to 1/35th scale…
Legs…changed the layout and added a spinning ballance under to a couter-weight and Gyro for stability. Added Leg applique armour…Changed hydrolic details and fittings…Cast metal effect Feet…Spring guards
Hull…Detailed enging, metal grills…Cast Body effects…converted to two crew positions…Ghain gun…Applique Armour Kit…Stowage area …rear door access…Main weapon and mantlet…exhaust systems…
I had fun with this…hope you guys like the job I did…
[img.nr] http://smallshopeu.com/Ivan__Ural%20Mountains2034/DSCF0042.jpg[/img.nr]
All images are here…
http://smallshopeu.com/Ivan__Ural%20Mountains2034/Photo_IVAN2034.htm
