Next on the bench
Here are a couple shots of my latest project, Classic Airframes’ Polikarpov I-153 Chaika. This was Classic Airframes’ sixth kit, so it’s long out of production. It included some nice resin & photoetched parts and a vac windscreen, along with the typical limited-run injection molded parts.
The fit is pretty good. All the mating surfaces needed sanding, and the gaps were only panel line sized. I used Zap-A-Gap on these. I had built and painted the cockpit years ago, before putting this one back in the box. The cockpit is a PE “cage,” with film instruments and a resin seat with PE belts.
I lost one of the tailplane struts, so I replaced it with one cut from a pastry tin.
To give you a size reference, here it is with it’s opponent on the Eastern Front, a Bf 109. Although nimble, the I-153 wasn’t much of a match against a Messerschmitt !
Thanks for letting me share !
Alright Bill… another masterpiece being born!! [:)] Looking forward to seeing this one materialize too, thanks!!
Take care,
Frank
Are you doing Russian or Spanish markings?
Pix,
A 109 isn’t a very big plane, but that one’s tiny ! Cool !
Chris
Great start Pix. Looking forward to seeing the progress on thisone.
Regards, Rick
Looking good! I picked their p-152 kit last year and plan to build my as a Nationalist Chinese aircraft. I’ve built only one of CA kits before and found it a bit rough going but utlimtately rewarding, so I’m very interested in how yours will turn out and any potential pitfalls.
Thanks Frank, wayne, Bossman, Rick, and waikong !
wayne and waikong - this will be a VVS bird, based at Minsk in June '41 (circa Operation Barbarossa). It will be finished in NMF, with green splotches.
This is the scheme
Thanks again !
That one Intersting little plane! I can’t wait to see the finshed product with camo job
Jason
Looks like the start of another great build pix. Keep us posted.
Hey - good one Pix,
Can’t wait to see it finished - thanks for sharing so far.
Thanks Jason, pingtang, and Lee !
This camo will be fun to paint. If you notice, the splotches avoid going “under” the markings. I’ve scanned & printed the decal sheet. The stars will be cut out as used as templates for drafting tape masks. This way, the splotches won’t go where decals are.
Thanks again !
