I do my tracks differently than most, but it never fails for me. You need Tamiya Extra Thin Cement and silly putty/ fun tack
when you are ready (before the fenders are on), tack all the wheels, sprockets, etc. in place with silly putty/ fun tack. DO NOT cement, unless you are someone who like to paint the tracks on the model.
Now, instead of making a length the entire run of tracks, i do it in segments. The first segment is about 15-20 links long. Cement the links together flat on your table with the Tamiya Cement. Tamiya Cement is REALLY strong once it is dry, keeping breakage to the minimum. Let the glue sit for up to 5 minutes, and start the tracks off at around the top of sprocket, then mould them downards and under the roadwheels. This gives them a definate place to be and ensures the tracks will be in the right spot. tweak the alignment if neccisary, and wait a few minutes (or an hour) to let the glue hold up.
Next, the top run. Make a segment the entire length of the top run, long enough to finish up what is on the sprocket and go half way around the idler. Then glue them. let them sit for a few moments, and as soon as they start to get stiff (3 minutes or so), they are ready to rock. Place them at the top run, connect them to the first run, and now your ready to add some sag. To do this, i simply take my two index fingers, nail to nail, and lay them along the top of the run. The curvature of your fingers will cause some slight, even sag in between the return rollers. If you want more sag, pull them down a bit, or, press harder with your index fingers. Skip this step if you dont want any sag.
Let that sit for a bit, and finish up rapping links around your idler and under the road wheels. So, you should have tracks under the first and second roadwheel, along the top run, and under the last two roadwheels. Gestimate the length needed to finish up the ground run, and cement it all together. And there we have it: a finished lenght of tracks. This method works for link and lenghters too. Now my question is: did i confuse you? anywhere i was to vaugue, let me know: ide be happy to go into greater detail.
