Newbe need advice!
OK, won an auction on EBay including rattle cans, and bottles of both enam & acryl. However, I got 4 bottles of Alclad II Lacquer, and this stuff seem very “thin”,
Is this Alclad for air brush only or will a brush work! Best uses for this stuff??
Pretty much AB only.
yes, airbrush only and best uses are for modeling aircraft which had bare metal (unpainted) finishes. If you’re a newby to the hobby then you’ll probably want to set those aside for awhile until you’ve gained some experience (and an airbrush )…have fun!
Airbrush only,here’s a link on how to use.Just Google Alclad,you will get a lot more
www.swannysmodels.com/Alclad.html
Alclad must be put on in a very thin coating, so it must be used over an undercoat. A gloss black undercoat is recommended for most use, but varying the undercoat can be used for special tricks. For the first few times you use Alclad, however, stick with the gloss black. I have successfully brushed it on some very small parts, but mainly it is for airbrushing.
