Well, the Armor factory is in full swing again, this time making a more varied group of vehicles.
I started out building a 1/72 scale Russian D-30 howitzer from Model Wheels. There is a ton of cleanup that has to be done! Still, it looks like it might build into a pretty decent kit:
Then I started on a PST 1/72 scale Russian T-54 tank. I only got as far as here:
Next, I decided to build a little 1/72 scale German scout vehicle from Matchbox that I got at Orangecon. It is the Sdkfz 232. I started out building the body:
Then I built the wheels and undercarriage:
Then, since it was so simple, I built the turret and then fastened it to the top of the hull.
As that dried, I also couldn’t refuse the calling of my 1/72 scale M-19 Tank Transporter, also from Matchbox. I got it at Orangecon aloing with the German Scout Car. Here is the cab being test-fit together. I have to paint the interior before I close it up for good:
Then there is the back cargo bed:
Then I started on the chassis, but didn’t do to much:
Finally, I commenced construction on another ACE kit, the BMP 2. Here is the hull put together:
From this angle, you can see that the usual gaps that normally happen at the front (indicated by arrows) aren’t as severe on this kit. This makes things much easier.
That concludes this tour. I hope everyone had a good time. Now to the veranda outside for more burgers!
[C=:-)] [dinner] [BG][BG][BG][BG][BG][BG][BG][BG][BG][BG]
