here is tamiya’s Fw 190A-3. I have had a lot of time lately. I built it out of the box with Model Master enamels. the instrument panel has had a subsequent application of gloss to simulate glass. Tonight and tomorrow afternoon I hope to apply decals.
I did the mottling with a double action airbrush and a lot of time.
to do that scheme however I dont think my airbrush can go that small, I have seen that scheme done in a review. I will try to dip it up. The first thing that comes to my mind is to use a tooth brush and spatter it, a bit messy but I would think it would do the job.
Yes, a sponge works pretty well for the “stippling” on Wick’s aircraft. I used some of my wife’s make up sponge, dip it in the paint and tap it on a paper towel until the paint is almost removed then slowly build it up the paint on the fuselage.
Have you applied the gloss coat yet? I’ve tried the permanet marker method before and experienced severe bleed through after the gloss coat was applied.
thank you everyone for your kind words. Today after drivers ed I will post some picsof decals.
as far as the prewash I drew the marker right over the plastic, then preped and painted as usual, with the blue it took a few coats to properly cover it. I got no bleading.
I added some weathering. Not done yet but getting there, I used a combination of mig pigments and ordenary chalk pastels. I added the broken gun barrel.
thanks, the only thing I have to do is add the canopy but I butchered it so I am waiting to figure out away to get it to work. and add the antenna wire, and brake lines.
