Needle Lube?
Alright, I’ve been doing a lot of reading here, and I would sure like to know what needle lube is, where I can get some, and is there anything to lube the o-rings inside the airbrush?
Thanks a bunch!
needle juice is good.
only link I have for it is www.coastairbrush.com
Only on the needle, you should never ever need to worry about the insides
you can also get it a www.dixieart.com and I ditto Woodbecks comment… it is a good thing to have… ESPECIALLY if you use acrylics but it helps a bunch with enamels too. Easier clean ups, better spraying (no paint clogging in the needle etc) are just a few of the benefits…
at about $5.00 a bottle it’s worth it… and a bottle lasts a looooong time! I’ve had mine almost a yr and it is still almost full.
I"ve used vasoline for years with no problems and its cheap.
you can use any kinda lube as long as it doesnt effect the paint.
