need some advice
hey guys hows the modelling going?? A quick question i just picked up academy’stiger 1 mid production with interior, Has anybody built it yet and if so was it a good build?? Also who makes a zimmeritt kit for this kit??
thanks again Aaron
Well, I haven’t built it myself, but have heard nothing but great things about it. As far as zimmerit, try Atak or Cavalier, they are resin and IMO, much more detailed than pe. If you do go pe, consider Eduard or Verlinden(if they make one). I’m sure there are more.
thanks tiger im lookin for to building it because in considering to build it for an up coming show in august so thanks for your help
No problem and good luck on your show. If your game, go to greatmodels and do a search under Tiger I. No doubt you’ll pull up a whole long list of Tiger goodies.
I have built the early version and it went together nicely, the transmission is to high so the top dose not fit nice and tight, other than that it’s a great kit.
or you could make the zim yourself. It really is easy, if you make a mistake you can redo it depending on which putty you use.
Dave
