What kind of masks would you use to airbrush this type of camouflage because this is a bit more elaborate than the patterns I’ve done in the past.
Personally I’d use Silly Putty. I’ve used it on complex Japanese and French Second World War camo schemes and it seems to work pretty well. There’s a brand made esp for masking stuff like this, I think it’s called ‘Panzer Putty’, haven’t tried it though.
I second the use of Silly Putty. It can be used for any kind of edge the builder wants. It can also be used to mask off wheel hubs for a great edge for tires. The builder can create the straightest of edges or feathered edges. It is reusable, and it is much cheaper than commercial masks. It is great!
Bill Morrison
The illustration seems to show hard edges on the segments. If that’s correct, I’d blow up/reduce the drawings to matching scale, and cut masks from Tamiya tape.
Laborious, I’ll grant you…but that’s probably to be expected taking on such a scheme to start with.
Cheers
I’ve seen these masks (and have a set for a King Tiger in the stash)-looks like they have two sets for T55’s-found these-
https://www.microworldgamesllc.com/product.sc?productId=9795&categoryId=-1
I ordered mine from Lucky Model but there appears to be several domestic suppliers.
I’ve used Silly Putty on several projects-good choice if you chose not to go with the taping or mask options.
Internationally, Silly Putty might be hard to source. In that case, the blue or white “poster tack” (aka “blu-tak”) can work as you can mash it to a reasonably fine edge and still remove it.
There is also a brand of commercial masks called “J’s Work” that are excellent. You could source them online.
Bill
Thanks Bill-I realize that I didn’t mention the name of the mask company in my earlier post…anyway, below is a link for the T-55 masks from a domestic source.
I like to get mine from www.bnamodelworld.com in Australia. For some reason they cost less and shipping is cheaper and faster. For example, I use Fruil Model tracks. BNA sells them for as much as $20.00 to $30.00 cheaper than American and European sources. Granted, it doesn’t matter much in the case of masks but many are available.
Bill Morrison
