I saw someone’s build of the AMT Classic TOS Enterprise where they downsized a pic of the bridge from directly overhead, printed it out, and inserted it under the clear plastic dome that goes on top of the saucer. I was hoping to pull off the same trick, but I couldn’t find a good pic in a Google search. Does anyone know where I can find an overhead shot of the bridge like that?
try blueprints. i also made the outer shell out of packing foam covered with several layers of fiber glass the elevator is about the size of a coke can
Hi dirkpitt77, I gather you are looking for an actual photograph directly overhead of Paramount’s stage set of the bridge. Although I haven’t seen one I think on one episode there was a shot looking down with the actors going through their routines; I will check with my son. Magoo
I don’t know if this will help but e-bay “toys and Hobbies” " uss enterprise bridge" has several models and playsets. One of these may have photos. You may even be able to assemble a kit and photograph it then downsize the photo. This may help then again maybe not.
