Need help interpreting building step
Hello all. I am currently building the Tamiya P-47D Thunderbolt “Bubbletop”. I have a question about step #4 on page 3. I’ve included a pic of the page. The kit comes with two POLY CAPS in a separate wrapper. In the building step it shows the placement of just one of the caps, between B12 and B6, directing “No Glue”. I understand this, however is the other cap used or is it an extra? Also I hi-lighted a second “No Glue” symbol. What part(s) is this in reference too? Then after the propeller assembly is pressed into part B12 for final assy., what is the function of part B25 that I have hi-lighted? Thank you for any responses, Ted.
That’s typically an extra.
Thank you, kind of figured. Do you know what the other do not cement is referencing?
I don’t have the full set of instructions in front of me but it appears to be explaining what that symbol means for the poly cap.
Oh right! Ok, yeah they are letting you know what the symbol means. I was looking too deep into it, thank you!!
My Tamiya P-51 had an extra poly cap as well.
