Need help IDing another vintage aircraft "thingie"
I volunteered to help catalog the finds from our TIGHAR aviation archaeology dig at College Park Airport in College Park, MD, last year, and am again appealing to the vast and untapped knowledge on the forum. One of our finds from what would have been the center of the original Hangar 2 at a very shallow depth is an information plate from some kind of power equipment. I’m hoping someone can offer clues as to what it might have been attached to.
The plate is aluminum (non-ferrous metal, anyway), about 1/16th-inch thick, and measures 3-inches wide by 1-7/16th-inches high. There is a mounting hole drilled in each corner. Although it’s hard to be sure, it appears that the plate had a white or silver border and dull green or brownish background paint. The lettering appears to be cast on the plate, since there are no embossing marks on the back side. The lettering, in block capitals and centered on the plate, reads:
WARNING (in 1/4-inch high letters)
OPERATE BLOWER FOR 5 (in 1/8-inch high letters)
MINUTES BEFORE STARTING (in 1/8-inch high letters)
ENGINE - GENERATOR (in 1/8-inch high letters)
Between the lines Warning and Operate Blower is a thin, elongated diamond shape 1-inch long. Any clues would be appreciated. And since I can never get the stupid [img] tag to work, please click on the link for a pic: http://home.earthlink.net/~mffowler/cp-idplate.jpg
My guess is an APU that had problems with internal fuel leaks. Sounds like something you’d see on a boat bilge pump starter.
The link to the picture was the best one I could take of this metal plate.
Current thinking among our group is that it was for something to help start airplanes, as opposed to being on an airplane, but I would like to narrow it down to at least pre- pro post-WWII.
From what I’ve seen (having worked in aviation museums from 1991 to 2001), that’s probably a post-war piece. It was probably red paint that’s faded. Definitely sounds like it came off of a start-cart of some type.
HTH,
Jon
Well, that’s a start! Could you send me ideas on aviation museums I could contact to try and get an idea?
It was most likely a standard placard on many different kinds of APU carts, maybe you could narrow it down to a brand by the paint color and phrases?
