Need help converting Tamiya Acrylics
Hey guys,
I have tried the conversion charts on the web, but I have had no luck finding the Model Master Acryl and Enamel equivalent of the these two types of Tamiya Acrylics
XF-51 Khaki Drab
XF-59 Dark Yellow
If there is not a straight equivalent, what would you use instead? Or, what would you mix from Model Master to acheive these colors. I appreciate any help you all could offer.
I am switching from Tamiya to MM for handbrusing, because Tamiya is terrible for handbrushing. I’ve tried everything, even using their thinner.
Thanks!
You could give the “Ultimate model paint conversion chart” a try, its pretty good & converts a whole load of different manufacturers paint;
http://www.paint4models.com/paintchart/paintconversionchart20100101a.html#
