Just hoping you keep in mind that without solid basic-modeling skills, it doesn’t matter what a kit costs… It’s only gonna be as good as the modeler is… I’ve seen a lot of folks madder’n a Bernie Maddoff investor at a high-dollar kit, when the problem was their not beng able to fix a warped part, fabricate a replacement part, or a big ol’ finger-print in a freshly-painted wing panel… Hope you don’t get a “Monday Kit” when you shell out the big bucks, too… It DOES happen, lol… (“Monday Kits” are what I call good kits, but YOUR copy was made on Monday when nobody on the line gave a damn or was hung-over from the weekend, and has missing/broken parts, short-shots, decals sheets that got printed off-register, etc). I’d hate to lay out 70-80.00 bucks for a kit that I couldn’t build, instead of dropping 12.00 on one I know I can fix if it’s ate-up…
Being an experienced ship modeler, you should be able to use most of the modeling skills you’ve developed over the years, but nothing beats experience with the genre as well… Aircraft are a different than ships, which are different than tanks, etc… Guys that built hundreds of armor kits sometimes have trouble with their first few aircraft, and vice-versa… Just build in sub-assemblies, and let that paint CURE before you handle certain parts… Sanding off fingerprints in the paint will, for instance, damage or even destroy all that delicate detail you paid so much for…
I generally shy away from advising anyone who’s new to the hobby or the genre to buy high-end kits, untill they get pretty good at the cheaper ones… The guys that do the opposite are generally quite experienced with the genre and have built dozens, if not hundreds of the “old” ones… I know that if I ever desired to switch over into the model ship arena, I’d be buying a lot of cheap kits to build up familiarity with what generally goes where first, before I ever laid out 40.00 or 50.00 bucks for a high-end one… (Yeah, that’s high-end" for me… Anything over 35.00-40.00 bucks MSRP is a NO-GO for me. And if it’s THAT high, it’d have to have a coupon or clearance tag to get it under the 30.00 mark, with VERY few exceptions)
The most I ever paid for a kit was 42.00, and that was an exception… It was a 1/35 M109A3 interior hull detail set and I got suckered into a bidding war on Ebay… But I needed it, since I was building six M109A3s for a diorama that a gal had commisioned, and didn’t wanna scratch-build six interiors… I used the one “store bought” kit to cast five more resin copys.
Speaking of casting copies, that’s what I do for many of the common details I can use from one aircraft to the next… For instance, I’ve several kits that call for 1/48th P&W R-2800 radials (two B-26s, three P-61s, two P-47s, and a pair of Bearcats). But rather than buy 12 after-market resin engines, I took the one complete engine from the P-61 kit and cost a couple dozen copies… Did the same thing with Allison, RR Merlin, and DB 601 engines, as well as AFV stuff lke transmissions, engines and main gun breech- blocks… I also cast copies of figures, both ground and flight crew, as well as tires with tread patterns I need… Just something to keep in mind if you decide that aircraft are something you’d get really serious about… I vacuform my own canopies too…
Anyway, good luck with your selections… I recommend buying lower-end kits in whatever scale you decide is best for you, and there’s nothing wrong with the Oldies… You just gotta put more work into them than you do the Shake & Bakes… But that shouldn’t be a problem for a guy that spends a couple years building a ship, lol… (Yeah, that’s a hint, lol)… Ya just gotta have a good parts box, and a fair selection of styrene sheet, strip, and rod ('course, you can make rod outta stretched sprue. That’s free, lol)…
I became a “serious” Gizmoligist and Scratch-detailer in the late-70s (what I built then is what I build now, more often than not), and no hobby shops were within walking/bicycle distance, and after-market parts were cottage industries (and VERY expensive), so I set about making everything I needed to super-detail kits… Luckily, I had received a Mattel Vac-U-Form set as a kid in the 60s… That was the single-most special tool I ever had, and I used it a LOT. (Still do… After going without one for about 10 years, I finally found another one on Ebay, and there’s even a guy that sells the plastic for it! there! Greatest canopy-making machine ever invented!)
It bothers me sometimes that times have changed so much though… People used to say, “Wow, he spent a lot of TIME on that kit.” to, “Wow, he spent a lot of MONEY on that kit.” So I’ll always try to steer a guy towards the Classics… Nobody ever lost a contest because he built an “old” kit versus a high-end kit, he lost because he didn’t build it WELL… (Unless you’re Von Manstein that is… He managed to “leave a seam” on an aluminum gun-tube… Somebody had it in for him that day…)
But I’m really just a tightwad…[;)] At least I think that’s the basic, underlying issue, lol…
Again, G’Luck…
