Need advice on making trees
Need some hints on making trees that don’t involve digging in the ground ( it is way too frozen here right now to do that 25 below zero to be honest !) thanx ![8D]
Visit your local Model Railroad store and see what they got in stock.
I like to build my trees from wire bundles/wire rope, they are sold over here in different length and thicknesses.
What you do is pull Wires(Twigs) or small bundles of wires(Branches) off and position them, of the sub-bundles you can pull smaller bundles or single wires to make smaller branches and twigs.
Very easy to position, putty to add volume/texture if desired, prime, paint and add flock.
I have even made a 1/8 cascading Bonsai using this method for a Diorama, it really allows you to get creative and position everything nicely.
Hope this helps.
great idea (model )thanks
I tried your tecnique with wires but it didn’t really look good at the end. Can you be a bit more specific and explain step by step?
You would REALLY be helping me out and after adding putty…how do you exactly texture it?
Cheers Pal
This is an almost 5 year
You really should look at the date on a post when asking a question and according to his profile, MadModelFactory hasn’t visited here since 03-16-2004.
Once a modeler always a modeler mate!
He doesn’t have to reply of course…I was actually hoping that someone else would be helpful.
Your right though,
Here’s a link to another tutorial aon making trees. Hope it helps.
