natural metal
What special preperation do i need to paint a natural metal finish. I am using model master buffing metilizers from a spray can. Also how far away should I hold the can to recive the best results.
Nick
Nick I have found that about 10 to 12 inchs with short and quick stokes does the best for me.Digger[:)][C):-)][:)]
Fisch:-
I’m no expert, but I suggest you prime first. The only metalizer finish I ever did turned out beautiful, and I primed with flat white acrylic first. Let it cure for at least two days before spraying the metalizer, or prime with a laquer or enamel first. That will also show up any flaws in the plastic too.
Rich
There’s some interesting tip and tricks at SnJ’s site that could possibly applied to metallizer
http://snjmodelproducts.com/info.htm
Thanks for the help[:D]
I think i got all the steps sand, polish, prime, apply several light coats, seal, apply decales, then seal again.
Thanks again for all your help
Nick
