[:D] hello friends:
This time I will use the Panther G Late Tamiya #35176 with IR, (the IR comes with the Panther G Tamiya #35176, then I will build it). This is the first time I will use the interiors of resin.
Kit & accesories list that I will use:
1.- Panther Ausf G - Late / Tamiya # 35176
2.- IR Section of the Panther Ausf G - Late / Tamiya # 35174
3.- Interiors - Jaguar #63504
4.- Compartment engine - Verlinden # 1203
5.- Photoetched - Aber # 35024
6.- Periscopes of resin - Royal Models (or maybe of Aber Photoetched)
7.- Metal Gun barrell - Jordi No. TG-10
8.- Antennas of photoetched - Dragón No. 3819
9.- Tracks of metal - Friulmodel # ATL-08
10.- Chains - Accurate Armour
11.- Bosch lights - Greif
As you can see, I think I will delay to add my first pic of my work in progress, because I need to sandpaper all the 125 pieces of the resin interiors.
I have just started to clean and sandpaper the Jaguar interiors. As you can see on the image attached, it is a little bit complicated to separate most of the pieces from the base because the resin is very thin; I will work on it with an electric sandpapering machine. The details are great, and I hope not to find any folded piece as sometimes happens with the resines.
[;)] Best regards,
