This is my new 1/35 Academy StuG IV, ít’s a rather easy build, all parts fitted fine… this is the reult, which is quite nice in my opnion since i haven’t got a really fancy airbrush (revell standard class)
3 pictures:
The stug without the side armour
and two with side armour
what do you guys think about my new kit?
Looks quite nice thijs. I really like the camo and the tools look excellent. [tup]
Are you planning on any weathering?
If I may suggest a couple little things:
Drybrush steel on the tracks, idler rims and drive sprocket teeth these areas would be shiny from wear.
It appears there is an ejector pin mark on the inside of the schurtzen (side armour) at the front, a little putty and sanding will cover those (or just sanding if they stick out from the panel.
Overall a real nice build, keep it up and [#welcome] to FSM
I haven’t weathred it yet, i’ll drybrush a bit silver on the tracks and on some parts of the tank itselve, it also needs a layer of mayt furnace to cover up the decasl(who are too shiny now)
I’ll post some more pics tomorow
It looks great , as said before just fill those irritating ejector pin marks , ( they always put them where they will be noticeable or unfixable (dragon indy links) ) as for the “purple” redbrown , its just a cruel trick flash does to unweathered camo, weather it a bit and it will look great , flash or not . And as said before [#welcome] to the forum and we all look forward to your future posts .
