Beautiful work! You just gotta love a F-4 in the Southeast Asia theme. Your construction, painting, & weathering were spot on! Great job!
tjs
tjs
Wonderful build of a wonderful aircraft showing wonderful modeling skills…
simply wonderful!
seriously…
Looks phantastic PJ!!! [ht]
Love the grime and oil on the bottom and the chipping and wear around the cockpit.
Thanks TJS. I never get tired of modeling the Phantom.
Drum thanks for your wonderful comments lol.
Thanks Gamera, glad you like my work.
That’s super PJ! I really like the subtle chipping around the cockpit.
Thanks Mopar. A sharpened silver Prismacolor pencil over flat paint works wonders.
I finally found a couple of pit pictures I had taken during the build. The IPs were painted and the instrument faces dry brushed then clear plastic cement was added for the glass.
The seats were pretty much naked without the added pe details. The face curtain rings were sprayed yellow then thin masking tape strip was cut and wrapped using two twerzers. Once the tape was on black paint was sprayed and when dry the tape was removed producing an even wrapped stripe.
That’s looks real good PJ. Doing a 1/32 phantom is in my bucket list.
Thanks cb. The 1/32 Revell is decent and actually has less fitting issues than this Tamiya and is lots less dinero.
Just excellent work. That grime streaking underneath is just fantastic.
Truly amazing artistry – someone’s getting their monies worth - I hope they appreciate it.
Thanks for your kind words.
Thanks. Artist’s oils work really well for this step.
I know there is often debate about how dirty operational aircraft should be but having dumped tens of thousands of gallons of fuel into those things I can say without a shadow of a doubt that you 100% nailed the underside. They could leave the base perfectly clean and come back looking like that just an hour later.
Thanks Tcoat. I try to stay on the realistic side when weathering a subject. Appreciate your input in this conversation.
TOTALLY missed this one Ernie!! These Tammy F4’s build up into some good looking models as I’ve seen at the shows. Paint and weathering are at a true premium on this build. You’re right too about it being HUGE at nearly 2 feet long!!! I went up against (and lost) against one of these for best aircraft of show in 2016 in San Antonio with my Fw190 D-9. That guys replication of this beast was as good as yours is here. Beautiful work bud.
Hey thanks Joe. This F4 had some minor dealings but at the end it all came together. Tamiya’s details are very good specially inside the pit.
Thanks for taking the time to look and post.
