I bought a Tamiya P-51B kit cause the plane looked really cool. I have done a couple of armor kits but have never done a plane, is this gonna be to difficult for me to do?
Hi miller41 not built it yet but i have one. I wouldn’t think that you will have any problems with it as tamiya are normaly exellent kits and fairly easy to build…Gregers
welcome miller41. I havn’t built the “B” model, I do have one on my short list of to build. I have done a couple of “D” mustangs from tamiya though. They are generally flawless and have no real problems, watch out for the fit of the engine panels to the body on the nose. If you dryfit and take it slow, the seam will look just like another panel line, just as it is supposed to.
Have fun, it’s your hobby!
hiya miller41, I doubt it will be difficult for you to handle… DrewH says it best with the engine panels as I had to dry fit several times to get the seam to appear as a panel line. But he’s right. Just take your time. I started in armor too and now I can’t get enough of aircraft.
Whaz up Miller41,
I built a few of the Tamiya 51B’s. Just like DrewH said, take your time around the nose section. Also dry fit the clear lense that goes on the wing(had to reshape the lense to fit properly). Two of the kits had this particular problem w/ the fit and the other one was fine(could have been a bad batch who knows[:p])
Other than that add glue and paint to the box and shack. TADA you have a 51.
The kit looks SWEEEET once shes built[:D]. Just take your time. If at any point you feel the need to make it into a lawn dart, just walk away because it will be there when you return[:p].
Happy modeling bud[:)]
Flaps up,MIke
Let me first say that I love Tamiya kits. I almost exclusively build Tamiya. They are the best in the business. But, it drives me nuts when people say " just add glue and paint to the box and shake". As great as Tamiya kits are, there is plenty of things that can be done to improve them. Tamiya could take a page or two out of Accurate Miniatures play book as far as cockpits go. For the money they get they could provide better detail. Molded in flight controls also drive me nuts. Either remove and reinstall them, or at least open up the area between the flight controls on the sides. Same goes for the trim tabs, control horns and cowl flaps. Why do we continue to get stuck with molded on tail wheels too? Tamiya is getting better with each new kit they turn out.
Sorry I got way off topic on that one [:o)].
To answer your question…no, its’s not to tough of a kit. They go together easily. If you feel that you need filler for a seam, stop and see whats wrong. Tamiya almost never needs filler. They are straight forward kits that are relatively easy to assemble. Out of the box will give you a good looking kit, but there is still room for self expression if you are so inclined.
Darren
Whaz up darrenbb,
RELAX MAN, its was only a figure of speach[:p]. In all my years in this great hobby, Tamiya hands down goes together extremely well w/out really any problems.
I also agree w/ you that Tamiya could go an extra step in their detailing process but then again we’re modelers. It just would not be fun if the companies did everything for us.
Flaps up,Mike
sorry,
Didn’t mean to sound as uptight as it came out [:)]. You make a good point about not doing everything for us…lol
Darren
Hey there…
Like Butz and darrenbb said… Tamiya kits are fantastic… provided you can read Japanese… haha!! Quality wise they’re definitely great… If this is your first kit i would suggest not assembling or putting in the engine… Use it for conversion kits or detailing kits later on… but since you’ve built models before I guess you might wanna assemble it… It should’nt be tough cos from what I’ve built I have always found Tamiya kits a breeze to assemble… But painting depends on the colour scheme… Tamiya kits only give colour codes for their own make hence a lot of mixing may be needed thus making the process messy!!! Anyway… do enjoy and have fun…
Cheers,
Nandakumar
You rule Darren…[:D]
Flaps up,Mike
Hey nandman83, I don’t know what Tamiya sells in Singapore, but there is no engine in any of their P-51 kits that I have built. For miller41, the kit shouldn’t be too difficult for you if you have some modeling experience. Ditto on taking care with the engine cowl and just take your time and follow the directions. Make sure you assemble the one piece lower wing to the fuselage first and then glue the upper wing panels to the lower wing and fuselage. If you assemble the upper and lower wings first you may encounter a major prblem.
Rick
rjkplasticmod,
SOrry about that… got confused with the ARII (Otaki) kit… anyway… thanks for the correction…
Cheers,
Nandakumar
My first kit was a Monogrm A6M and boy, that kit sucked!
My second was a Tamiya Spitfire mk Vb. You can just imagine how eye-opening that experience was. From then on, I avoided Monogram (some passed through) and got more Tamiya kits I could lay my hands on…
