multiple badges in signature
how do you show multiple group build badges in your signature line without going over the max of 512 characters?
You have to put them into one image. You need something like paint.net. I am not very good at explaining this, and it took me a while to work it out. In paint, you select file and then new and then make it the size you want. You then use the layers function to put each image in to the large one.
Either that, or you can use a GIF animator.
let me try to help bish clarify. it is one graphic file. i use photoshop but any graphic program would work.
  1. start a new file 62 dpi (mine is GB WORKING).
  2. downlaod the first badge, open it (or cut and paste) into working file.
  3. size the badge
  4. crop it. export as GB 1 BADGE
  5. save as GB WORKING.
when you get a second badge open GB WORKING
add second badge, size and move it next to first badge
crop and export as GB 2 BADGES
upload to photobucket or whereever
replace IMG code in your signature with the new one.
hope that helps.
Thanks for the help guys. I’ll go get a copy of photoshop or something in give it a go
unless you are a serious graphics person, photoshop is way more than you need. i think a lot of folks do photoelements but you could probably find an inexpensive paint progarm too. just more mouse clicks do do the same thing
Badges!? We don’t no stinking badges
