I finally got some decent shots (with a good camera and macro lens) of my old Tamiya F-117A project showing some of the cockpit detail and lighting I had done. The cockpit includes a PE/resin kit upgrade from Verlinden as well as fiber optic panel lights and LED illuminated screens. The intent was to get the screens to have that ‘greyed out’ look that a normal CRT tube (ie: television etc.) has when the tube is off. When on, the grey disappears and the bright green of the monochrome tubes shines through.
The nav lights in the wingtips were extremely thin so I used lightsheet to get the illumination there (shines through top and bottom). The rotating beacons are assembled from two LEDs and a short bit of red acrylic rod. One LED is a soft steady on, and the second a brighter blinking to try and simulate the flash of the reflector each time is spins around. The LED blink is a little too quickand doesn’t have the slight fade in/fade out you see in a true rotating beacon, but it gets the job done for the most part.
Anyway, this was the old kit, and my inspiration for the new project I’ve been researching here:
CRT screens (illumination off) and front panel:
Radio stack and switch detail on stick:
Seat detail:
Right side panel detail:
Left panel and my gimpy attempt at a scratch built throttle!:
Top down, side panels and seat:
Top down, illumination turned on:
Illuminated CRTs showing screen detail:
CRT detail 1:
CRT detail 2:
Fully lit cockpit tub:
Fuselage with external APU cart used to supply power to model:
Full fuselage with rotating beacon and nav lights:
Rotating beacon detail (acrylic rod):
Nav light (wingtip) detail:
Brian~
