Mr.hobby aircraft color paint sets
hi everyone …im trying out some new paints for my old revell 1/32 spitfire. and thinking of trying Mr.hobby paints that i bot back a few years ago . Mr.color aircraft sets …ones is the u.s navy colors …and the secoud one is the british camo #1 …and the third one is interior aircraft set . has anyone used them …and whats ur thoughts are about this line of paints ???. i,ll be airbrushing the interior with there #(364)-bs283 aircraft grey green . i opened it up for mixing …and it smelled like acetone …i.m not sure cuzz its first time using this brand of paints . i thought acetone is hot to plastic …not sure …[*-)] … and i,m not sure how to mix with there 110 thinner ., how do,es it go down , how do,es it dry ???..matt or is it a gloss???.
These paints do stink, that is for certain :slight_smile: I don’t know what is in them but I have heard them described as synthetic lacquers. They are not to hot for plastic. I use them all the time. Most are semi gloss unless otherwise indicated. I believe their gloss sea blue is in fact ‘gloss’ .
You don’t want to thin them with 110 thinner. You want to get Mr Color Leveling thinner. I love using these paints except for three things:
  1. The smell
  2. They have some minor adhesion issues (had areas life off when masked over with blue painters tap or Tamiya tampe so make sure you wash your parts before using so they are free of any body oils or mold release agents).
  3. They don’t brush paint very well (maybe someone knows how to get them to behave with a paint brush?)
What I do like about them is their color accuracy. They airbrush beautifully and dry fast. They don’t go bad. If they start to dry up in the bottle you just add some leveling thinner, let them sit over night, then stir.
Also, you can thin them in the bottle and it will affect their self life (which seems infinite).
They Are Awesome paints. Thin with Mr. Color leveling thinner. Nothing else. They are lacquers. Thin them 1 part paint to 1.5 parts thinner. In other words, thin alot. They dry to a semi-gloss sheen.
yea… i too try,ed to brush the paint on cbaltrin. and that too went over like a leadzepplline. so then spray light coats ???..ok ido have the leveling thinner …but whats the 110 thinner for ???
110 Thinner? You mean the 110ml bottle size? They all can come in 110 ml size. If you mean the blue label thinner, or Hobby Color thinner, its for the H series Mr. Hobby Aqueous paints. It has a citrus smell.
oh …ok …thats good to know …always wounder,ed …well i,ll give a “”" shot ‘’’ tonight nathan . and thanks cbaltrin …if all go,es well i.ll use the second set ( british camo #1 ) for the top side . happy modeling guy cheers
