Hello,
I filled some gaps with Mr Dissolved Putty and now, one day later, some spots are transparant and some white.
Is it supposed to be all transparent?
Greetings
Hello,
Greetings
mandrake, i am a big fan of Gunze Sangyo products, mr. hobby etc. but i dont use the mr. dissolved putty, because they have a product called Mr.surfacer 500, i acts like dissolved putty to but much more easy to use. if you are going to use putty, i suggest the Tamiya “Light curing putty”. dries in 2 mins under direct flourescent light. or you could use the tamiya regular putty.[;)] but that dries longer.
I have a PM Ho 229 from which I’d lost the canopy, so I made a balsa plug the other day, and coated it with Mr Putty. That was the first time I’d used it. I suspect that if you had some clear spots, and some white spots, then you didn’t stir it well enough. I didn’t dry it under fluorescent light, just sunlight. It dried fairly slowly, though.
