MP Armbands? (Brasards)
Any sources or ideas on how to give a 1/35 soldier an MP brasard?
I thought that paint might not have the texture…and I can’t paint that well…
Any ideas?
I have seen and done similar additions a couple of ways.
The first was a thin strip of putty rolled out on a piece of talc covered glass first and trimmed to the required size. Then you lift and add to the figure and crease/fold etc. with a toothpick or other blunt thin object.
The other was a piece of lead foil placed on figure and painted in place. Cheapest source is wine or champagne bottle foils after consumption. A secondary is the safety seal of Tylenol or other medication packets.
The putty used for the first was the often referred to DURO it’s from the U.K. however…
LePage makes the same thing for North America. I have found this in Canada at Canadian Tire and also at the Home Depot in Canada and in the U.S. Two-part ribbon epoxy is what it’s called.
It is usually in the plumbing section or fasteners. It comes in two parts that when you mix together equal parts gives you one uniform color and it adheres great to the styrene and plastic of figures. It can be sanded, shaped, sawn into etc. when cured and takes paint without any prep work.
I have used it to replicate shell dressings on figures and bandages on heads or to add a “stuffed” look to the figures pockets etc.
Hope this helps.
Cheers;
Gregory
The putty referred to is called Kneadatite, I don’t think it’s been called Duro for some time. It isn’t from the UK, though Games Workshop market it here as “Greenstuff”. Another alternative, which is equally suitable for fine details, is Magic Sculpt. It has a different texture to Kneadatite, which you may find easier to work with. Both are sold by Michael Roberts Ltd, among others.
Another possibility for tackling this problem might be decals. I know Hudson & Allen make uniform decals in 1/35, though I don’t know whether the range includes MP brassards.
What I would try is to print out “MP” on your computer in various font sizes.
When you decide on one size that works, cut it out with a keen hobby knife. I would attach it with white glue to a piece of either the lead foil suggested on one of the other replies, or if you don’t have any lead foil handy use a piece of masking tape folded on itself and cut it to the proper size.
Hope this helps…good luck!
