Most certainly not similar to the Constitution
Well, it all depends on WHICH Anglo-Dutch war you are talking about! Certainly your commentary holds true for both sides in the first war (there were three!), but by the beginning of the second, the English had discovered and employed the line of battle with its three divisions (van, main, rear), and used it most effectively against the Dutch. The Dutch caught on by the end of the second war and did likewise. Same goes for the ships involved. In the first war, MOST of the Dutch ships were in fact converted merchantmen, and a large portion of the English ships were as well. But by the end of the second war, the merchant ships were pretty much gone from both fleets (with the exception of fireships), and the English fleet had a over a half dozen first rates from 90 to over 100 guns each, as well as a large number in the 70-80 gun range (50’s were used much like frigates in the 18th/19th century). The Dutch never built three-deckers (their harbors couldn’t take them), but by the third war, they had a dozen 80-84 gun two deckers that were just about as big as anything the English could throw at them, plus dozens more in the 60-70 gun range, and all were purpose-built warships designed to fight in line-ahead formation. You might note that at Trafalgar, Villeneuve’s flagship was ‘only’ an 80 gun two decker! True, these wars didn’t take place in such widely-scattered areas as did the later Napoleonic wars, but there were still a number of ‘incidents’ that took place in the Caribbean, the US East Coast, and elsewhere (such as the retaking of New Amsterdam by a Dutch squadron, De Ruyter’s squadron cruising in the Caribbean, action in the Med involving the Smyrna convoy, and raids by both sides along the West Coast of Africa). Essentially, all the tactics and strategies used in the 18th and 19th centuries had their source in the Anglo-Dutch wars (convoys, blockade, line of battle, sub-divided squadrons, purpose-built warships, etc.)
I grant you that fleets made prodigious strides during the 3 (Three [:D]) Anglo-Dutch wars. The largest ships of the fleet both increased in number, and approached 18th century second rates in nominal muzzle count and weight of single broadside, if not in actual firepower. However, the bulk of the battle line even after the thrid Dutch war was still made up of ships that were no more than half way between a typical ship of the first war and the small 64 gun third rate of mid-to-late 18th century. Indeed, the fact that the largest ships of 1690 battle line had indeed approached or equaled the nominal muzzle count of later first rates only served to distort the average and disguise the comparative feebleness of the ships that made up the bulk of the battle line even as late as 1690.
Let’s look at the French fleet of Beachy Head in 1690. The French at the height of Louis XIV generally built extravagantly in size and gun power compared the Dutch and English, and their fleet better serves to illustrate the still very significant difference in size of the bulk of the ships of the battle line then and those of the line 100 years later. The French battle line in question consisted of 79 ship totaling 4600 guns, including swivels. I don’t know how many were great guns and how many were swivels, so let’s include the swivels in the tally as well. We find the French fleet mounted on average 57 guns per ship, swivels included. However, in the French fleet were 3 120 gunners and 5 other ships mounting over 100 guns. If we remove these atypical Premier Rang Extraordinaires from the average to better see the average size of the majority of the battle line, we find the remaining French battle line mounted only 51 guns per ship, including swivels. The boardsides of a later 74 would certainly not count any swivels or musketoons, nor would they count the big carronades that would not be invented for another 100 years. So while big prestige ships such as Royal Luois and other Premier Rang Extraordinaires proliferated, the bulk of the battle line was still made up of much smaller ships than would never be continenced in the battle lines of late 18th century. In fact, the fmuzzle count of the median ship in the battle fleet of 1690 has not grown very dramatically over those of the 1st or second Dutch war. For the average ship in the battleline, the growth that occurred between the first Dutch war in the 1660 and the war of Grand Coalition in 1690 would have to more than double before the umbiquitious 74s of the Napoleonic war can be matched.
P.S. The Dutch did build 3 deckers. 15 of the them in fact, between ~1685 and ~1710. But it is true that they built none both before or after that period.
Interesting
Well, I have never heard of a Dutch three-decker from any period, let alone the Anglo Dutch wars. You may be thinking of ships like ‘Gouden Lieuw,’ the flagship of Cornelis Tromp, but that in fact was best described as a ‘two and a half decker’ of some 86 guns. Yes, there were a lot of smaller ships in the fleets, but when you look at the numbers of the largest in each fleet, you will begin to see what I am talking about. As far as actual firepower for these big boys (80 gun plus), the lower deck was normally equipped with ‘Cannon of Seven,’ which are 42 pounders, while the first rates of Nelson’s time (and the British and French 74’s too, though Spanish first rates and under were usually equipped with 28’s!) were equipped with 32’s (Victory was originally designed for 42’s). The main reason for this was a 32 was quicker to reload, but that doesn’t mean much when you were facing the first blast! There were reports of ships actually sinking after being hit with just ONE broadside from a ship like ‘Royal Sovereign’, and it was common during these battles for commanders to have to shift ships a number of times as each became wrecked by gunfire (Cornelis Tromp was forced to change ships at the Texel so many times, the the English commanders asked if there was one, or three Tromps fighting that day!).
Each of these comparative monster ships formed a ‘hard point’ in the line, which was reinforced, and formed a reinforcement for the lighter ships. But just because there were lighter ships in the squadron was no excuse to shrink from battle, and many times several of these ‘smaller’ 50 gun ships would team up to take and destroy a large first rate (this is what happened to the first rate ‘Royal James’ at the battle of Solebay). Also, your ‘averaging’ of guns per ship is suspect as well, as there were quite a number of small scout ships for all fleets that might only have a dozen guns or even less, and fireships are also included in the total number of ships involved (and a typical Dutch fleet at the end of the Anglo Dutch wars would have at least a half dozen or more of these). And when you compare that with the Dutch Fleet at the beginning of the First Anglo-Dutch war, in which by far the largest ship in the Dutch fleet was the converted Merchant ship ‘Brederode’ of only 54 guns, I think you will agree that your ‘averages’ are more than a bit scewed!
Essentially, by the last of the Anglo-Dutch wars, there were few ships in the line on either side that carried fewer than 50 guns, and most were in the 60-70 gun range, and the same was true at Beachy Head. Add to that that there were literally as many as a hundred ships or more per side, and you get an better idea of what I am talking about! And the ‘smaller’ 60-70 gun ship was a standard lineship until the end of the 18th century (the Spanish navy at the beginning of the 18th century was equipped entirely with 60-68 gun ships, and was essentially completely destroyed by a pretty standard British squadron of 1 x 90, 2 x 80’s, 8 x 70’s, 7 x 60’s, 2 x 50’s and 2 frigates at Cape Passaro in 1718; such would not have been the case if the opponent was Dutch!)
