Monogram P-47D Razorback-finished
Hi, everybody!
I have finally finished this kit, which I first started back in 2006, when my buddy Brian Spruyt won it in our club raffle, and gave it to me, because he didn’t build aircraft. I started it with the intention of giving it to him, when I finished, but he passed away shortly after that. I had the fuselage halves together and the wings and horizontal stabilizers attached, and there it sat, until last year. At the start of 2009, I made a resolution to finish 12 kits that I had started in the previous years (here’s the thread, if you’re curious to see the others: /forums/p/107668/1064888.aspx#1064888).
I’ve worked off and on since last year, getting stuck from time to time, but this week, I was off, and I wanted to finish it for our monthly meeting yesterday. So, here is the completed model, finished as Lt. Frank Klibbe’s “Little Chief”, in its final version.
From the port side, front:
and from the starboard side, front:
A view into the cockpit from the starboard side:
and from port:
You may remember that I’m a big fan of Monogram kits, and that the figures that they included were one of the things that I always really liked. The pilot in this kit is no exception. Here’s Lt’ Klibbe, sitting in his office:
As a raffle kit, it was missing the clear parts and the decal sheet. I used EagleCal’s “Little Chief” sheet to replace the missing decals. Here’s the nose art:
I’ve learned some things, both in this build and in others that I completed while this one was in progress. I used Squadron’s vacuform canopy, to replace the missing kit part, and I also masked it using Parafilm. Both were firsts for me, and I learned that a vacuform canopy cut from its carrier and then masked is a very fiddly thing indeed. I used Silly Putty to support the canopy, when I cut it out, but I should have masked it first, before removing it from the carrier plastic. Once cut, it was just too weak, even with putty it in, to cut the framing effectively. Eventually, I cut pieces of Parafilm and filled the panels. But it came out ragged. In the future, I’d mask first, then cut away the carrier and paint.
Colors were applied in the sequence primer (WalMart’s automotive), then the gray, then the OD (Tamiya aircraft colors) all via rattlecans. Then a layer of Future (brushed), and then the decals. The EagleCal decals settled down without solution, which I used only on the Indian head. Some of the stencils did lift off during handling, though, and I re-attached them with Future. Then it was several coats of DullCote to seal the decals.
Though the weathering was light-“Little Chief” was well-maintained, and even waxed regularly-I had a mishap. I was using oil paints to apply a filter to fade some panels, and though I had used DullCote to seal the basic colors, I managed to remove the OD on the starboard wing. I was able to mask everything again, though, and reapply the OD, and in the end, it looked like a replacement panel, since the color is a little different.
And I learned a little bit about applying large decals to curved surfaces. The Indian head wound up wrinkling, and I should have cut it, and also not applied setting solution to the whole thing at once, but should have worked from one end to the other (a tip from a member of our club).
But in the end, I’m happy with the result. I’m not a competition builder, I build what I like, for my enjoyment. I like these old Monogram kits, too, though I’m eager to try the Hasegawa and Tamiya Jugs, too. But I’m glad, finally, to have finished, and to offer this as a tribute to my buddy Brian. Thanks, Brian, and here’s one to your memory (a beer as well as the kit), we miss you around here, man!
Thanks for looking, and comments/criticisms are welcome!
Brad
Nicely done Brad. You did the oldie kit proud.
Regards, Rick
[dto:] I built that kit early in my ‘return’ to modeling and although it wasn’t a terrible kit, it does present some challenges. You’ve done a fine job on it-looking forward to seeing more of your work.
Nice work on what apparently was a very challenging project. I have a soft spot in my heart for Jugs.
Darwin, O.F. [aln]
Lovely jug, Brad! It sure turned out well!
Nice looking P-47…Well done[Y]
Thanks very much for the kind words, guys! I have another Monogram P-47 in progress, the bubbletop; my buddy Brian gave me that kit along with this one, and it was also one of my 2009 resolution builds. I’m finishing that one in natural metal finish. It’s already benefited from lessons learned on this build.
Has anyone else used Parafilm to mask canopies? It was tricky with this build, but I think under better circumstances, it could work quite nicely.
Apologies to viewers about the large images, sorry that you may have to scroll to see the whole pictures. When I posted this yesterday, the images showed as the standard thumbnails that the forum uses, with a bar at the bottom of each directing the viewer to click to view. But today, I see the photos default to full size. I know that’s one of the things about the current incarnation of the website, that annoys some members, so I wanted to let everyone know that I didn’t intend to set the pictures up that way.
I like how “Little Chief” turned out for you. I did that one myself some months back and really liked it.
It’s really cool, isn’t it, how those older and very basic Monogram kits end up when you’re done with them.
Nice work Brad! I can totally understand how you feel about learning through the build - I learned a huge amount in the process of building mine.
Like you, I used the Eagle Editions decal set - super quality product. But, I see the area under the victory markings is red. Where did you find that? Don’t get me wrong, I’m not criticizing you at all, I just hadn’t seen that before.
In any case, great work, and thanks for sharing!
No offense taken, that’s a good catch, that was a mistake I made [;)]. I had looked at a color photo and thought that the kill markings were in a red field, because of the contrast with the rest of the OD surface. Having masked and painted, I later found a text reference that described it as a different coat of OD. Apparently the aircraft was repainted or touched up. But by that time, I’d already had the victory markings on.
I bet it still looks good on the shelf. Nice work on an old kit. I sympathize with the vacuform canopies. I’ve ruined more than I’ve kept. By the way, the pictures look great on my computer. They seem to be the correct size. Rick.
I think that glitch is a gremlin in the software, but I usually only need to to do a quick refresh of the page and then it’s fine… Sometimes I’ve clicked onto a page and photo loads huge, but then resizes itself while I’m wathcing, lol…
Hey Baron nice Thunderbolt! Somewhere stashed away at my parent’s place I have a few photos of a few Razorbacks in NMF. They were part of my grandfather’s squadron when he was stationed in China from 1944-45. They started out in 42’ in North Africa with Airacobras.
Thanks, Rocker! It was a fun build, and fun to practice some things I hadn’t done before, like working with a vacuform canopy. I’m a little disappointed in the decals, because the squadron codes on the left side of the fuselage have cracked and flaked off a little. I used Future to repair the area, but I didn’t expect it to happen.
