Monogram 1/48 B-29 oxygen tanks needed!
Any one have the oxygen tanks from the Monogram !/48 scale B-29 they don’t need? Need a set for a project. Will pay postage, trade, cash, etc.
Thanks
Well, if you can’t find them, they are the easiest things in the world to scratchbuild, and they look a lot better than the group of tanks molded together in most models. Simply round off a piece of sprue the right diameter, then cut it to the proper length. The bits for the regulator on top (if there is one) are too easy to make from little bits of plastic. And if a frame for, say, three tanks is needed, Evergreen strip or similar brand will do that in five minutes tops. Generally, they are painted a merry bright green. Good luck.
Are you referring to the piece that has 10 tanks attached by a single center strip in the shape of a shallow arc
Yep, those would be the ones. Got some you don’t need?
SureDo…I have one in the ol parts box…shoot your home address to ezbluesix@hotmail.com and I’ll put it in the mail…
