Moebius Ford F-250
Used the F-250 Conversion and Upgrade kit from Fireball Modelworks on this one. Also installed a Farm Jack on the sratchbuilt tool box. Farm Jack as well as cab roof lights are also from Fireball. Model Car Garage Moebius Pickup P/E Detail Set for the emblems. Paint is Tamiya without clear. Fun build!
I like it, good job !!
I really like the look of these Moebius F series trucks and this one built up very nicely. Great work on this one.
Simply stunning.
Looks great!
Hmmm;
4-wheel drive huh? Where are the keys?
What a gorgeous clean perfect build! Look’s like you shrunk an actual truck! I’m not much into pick-up trucks but you’re inspiring me to try one. I’d love to see what you can do with a late 40’s/ early 50’s Ford or Chevy. Thanks for sharing!
Excellent conversion with the Fireball conversion parts for a 70 model. There is a couple things that are not right with the Moebius kit. The front turn signals are yellow on the side under the grill shell for 1970-72 models. And there is a red marker light on the side of the bed at the rear for 70-72 models.
For any questions on 1967-72 Fords, you can find the info here:
https://www.fordification.com/tech/67-72ID_01.htm
https://www.fordification.com/tech/schematics.htm
I am very familiar with these trucks having owned a 72 F-100 2wd, and now having a 70 F-250 4wd Crew Cab. I plan on building a kitbashed Crew Cab.
