Looking for some advice on using the Model Master Metalizer paints. I’m doing the exhaust on an F-14 and want to use several shades (Aluminum, Burnt Metal, Jet Exhaust). The question is- the aluminum is a “nonbuff” and the Burnt Metal is “Buffing”. I did the aluminum already, should I seal the aluminum before doing the burnt metal to avoid damage when buffing? I just dont know how sensitive it is- will buffing with a tissue dmage it or should it be ok if fully cured?
Thanks in advance!
