Working on this for “THE GROUP BUILD TO END ALL GROUP BUILDS, THE GREAT WAR” and thought I would share here also. The kit parts and fit was on the poor side but once together made an alright base to add to. When complete believe it may be a good looking build.
ERIC, DM, NATE - Thanks for the comments guys, they are much appreciated [:)]
DM - “Machine Gun Drains” ? If you mean for the barrel, I had drilled out the water jacket and used 1/32 brass rod for MG barrels or is there something else I’m missing?
Did this to all the MG’s, just hard to see in the pics I posted. If it was something else let me know, your advise is always welcome and appreciated.
Rob I remember these kits when they first came out. They were awful, You have done a great job so far and all I can say is congrats on tackling one of these, I look forward to seeing you progress on this one.
good work so far, your pics don’t show it, but the 6-pdr QF had a small but noticeable taper, the kit barrel being a fairly good guide to the taper, obviously ignoring the very ovoid nature of the item… [:(]
TERRY - Thank You. It was a bit fustrating at first but now it has become quite enjoyable even though there are still some problems with it that I did not correct. Might give it some time but believe will be building the “Female” and the “Whippet” at some point.
ANDY - Thanks Buddy! Go ahead and check out “The Great War” GB, there is a lot of great work being done (most of it flys though [:O])
MAJOR - Thank you Sir.
JON A ITS - Thanks for stopping in. You are correct, they should have a very small taper to them. To be honest the barrels and the incorrect shape of the back of the sponsons really bother me. Used .156 dia tube for the guns which gave the right size but did not allow me to taper. I do believe these look better than the kit supplied ones, they were awful. The guns are lightly attached and I have plans on spinning some new barrels on the lathe.
Very cool! Love the pre-shading, it’s going to give her nice ‘pop’.
Built one years ago and well, didn’t fit all that well and I used the old, paint, wash, dry-brush style so she turns out pretty dull. I’ve been getting an itch to go back and do another with what I learned since then.
BTW: I see you’ve used green here. I remember something coming out years ago claiming as ‘land ships’ they were painted battleship grey. Then again pretty much every painting I’ve seen of them has them in green though.
Oh man, this is beautiful! Another proof why pre-shading rocks!!! You did it perfectly. I give you a score of 9.5. I would have given you a score of ten if it was a German… [:D]
MAJOR, WBILL, SPADX, DOOGS thanks guys. Glad you like her always good to hear your feedback and thanks for taking the time to look.
GAMERA - The reading I have done, believe the early MK I and II’s were gray. Not sure of when or what MK but the later ones were a brown color. The pics I posted are hard to tell but used Russian Earth Brown for the base color. It looks more brown here in person but it is close to a olive drab think maybe the flat black pre-shade might make it look this way? Thanks for taking a look.
If you build another one sure would like to take a peak at her [whstl]
