Can you mix a gloss and a flat paint to create a semi-gloss?
Maybe … you can mix Future (which is a gloss) with Tamiya XF-21 Flat Base (which is the base they use for flat paints) and get anything from semi-gloses to flat depending on the ratio of Future to XF-21.
Hey Hey!!! [swg][swg][swg]
I don’t see why not as long as they are the same type of paints!! You can never mix two different types of paint!! I’m sure you know this!! I learned how bad it could get the hard way!! I thought I had two of the same types and mix them!!
Well tried to mix them!! It just clumps up and makes a big mess!! Good Luck!
[8D][8D][8D] Cheers!! [8D][8D][8D]
[8][8][8][8] Kelley [8][8][8][8]
