I am just in the beginning stages of planning out the building of Tamiya’s P-47M. It calls out 2 parts XF-5 (flat green) + 1 part XF-8 (flat blue) for the interior of the cockpit. I have neither, but I do have X-4 blue, and X-5 green. Tamiya does not list these with a particular sheen, just simply the color. Can I substitute them? Will it make a difference in the color when mixed?
The instruction call out XF-4 for the areas that would be zinc chromate. This mix for interior green will be considerably darker.
Flat vs. Gloss doesn’t matter, they will mix fine. I thought the whole interior was basically Dark Dull Green, or Green zinc chromate mixed with black?
I agree with Nathan- flat or gloss doesn’t make much difference. But there are a lot of shades of green available in paints, and likewise for blue. You’d need to mix up both colors and see the result before deciding if you can mix gloss blue with gloss green. Interior colors are more of a problem than exterior, because you can always simulate a weathered color but interiors do not weather nearly as fast as far as chalking and bleaching.
Thanks for the help. I am wondering if the colors will be the Same shade. All I really Care about is getting it close , not too far out there. I will experiment mixing small amounts to see what it looks like, I appreciate the input,
